*alereferencesystemgroups()
Creates an alereferencesystemgroup in HMASCII format.
*alereferencesystemgroups (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the alereferencesystemgroup.
name
The name of the alereferencesystemgroup.
color
The color of the alereferencesystemgroup. Valid values are 1-64.
To create an alereferencesystemgroup with ID 100, name "my-entity", and color 1:
*alereferencesystemgroups(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
