*moment()
*moment (id type locationid inputsystemid comp1 comp2 comp3)
HyperMesh HMASCII Command
id
The ID of the load (must be unique).
type
The type of the load.
locationid
The node where the load is applied (must be a valid node).
inputsystemid
The reference coordinate system of the load (must be a valid system or 0).
comp1
The x component of the load.
comp2
The y component of the load.
comp3
The z component of the load.
This must follow a *loadcollector() definition.
None.
