*dampings()
Creates a damping in HMASCII format.
*dampings (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the damping.
name
The name of the damping.
color
The color of the damping. Valid values are 1-64.
To create a damping with ID 100, name "my-entity", and color 1:
*dampings(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
