*independentnodes()
*independentnodes (node1 node2 node3 etc.)
HyperMesh HMASCII Command
node[1 to n]
The ID of the independent node.
This command must immediately follow a *rbe3() definition. There must be as many nodes defined as stated in the *rbe3() command.
None.
