*panels()
Creates a panel in HMASCII format.
*panels (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the panel.
name
The name of the panel.
color
The color of the panel. Valid values are 1-64.
To create a panel with ID 100, name "my-entity", and color 1:
*panels(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017.1
