*designpoints()
Creates a designpoint in HMASCII format.
*designpoints (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the designpoint.
name
The name of the designpoint.
color
The color of the designpoint. Valid values are 1-64.
To create a designpoint with ID 100, name "my-entity", and color 1:
*designpoints(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
