*tablecolumnvalues()
Sets the value of a cell in a table in HMASCII format.
*tablecolumnvalues (value)
HyperMesh HMASCII Command
Sets the value of a cell in a table in HMASCII format. Must be between *tablecolumnstart() and *tablecolumnend().
Each call to *tablecolumnvalues() defines a value in the next row.
value
The value of the cell.
To create a table with ID 100, name "my-table", 4 columns (integer, double, string, elements), 3 rows, and column labels indicating the data type:
*tables(100,"my-table",11,0,3,4)
    *tablecolumntypes(int,double,string,elements)
    *tablecolumnlabels("Integer","Double","String","Elements")
*tables_end()
*tablecolumnstart(0,0,1,3)
    *tablecolumnvalues(2)
    *tablecolumnvalues(7)
    *tablecolumnvalues(1)
*tablecolumnend()
*tablecolumnstart(1,0,4,3)
    *tablecolumnvalues(2.5)
    *tablecolumnvalues(3.14159)
    *tablecolumnvalues(-2.5)
*tablecolumnend()
*tablecolumnstart(2,0,6,3)
    *tablecolumnvalues(A)
    *tablecolumnvalues(B)
    *tablecolumnvalues(C)
*tablecolumnend()
*tablecolumnstart(3,2,2,3)
    *tablecolumnvalues(10)
*tablecolumnend()
Incorrect usage results in an import error.
Version History
11.0
