*weld()
Creates a weld element in HMASCII format.
*weld (id,type,node1,node2,dof)
HyperMesh HMASCII Command
This must follow *component(). The element will be assigned to the most recent component created using *component().
Nodes must also be defined using *node() before creating an element using those nodes.
id
The ID of the element.
type
The solver specific element type.
node1
The ID of the first node.
node2
The ID of the second node.
dof
The DOF (1-6) of the element.
To create a weld element with ID 100, solver type 1, nodes 1 2 and DOF 6:
*weld(100,1,1,2,6)
Incorrect usage results in an import error.
