*terminations()
Creates a termination in HMASCII format.
*terminations (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the termination.
name
The name of the termination.
color
The color of the termination. Valid values are 1-64.
To create a termination with ID 100, name "my-entity", and color 1:
*terminations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
