*groupslavebox()
*groupslavebox (id xmin ymin zmin xmax ymax zmax)
HyperMesh HMASCII Command
id
The ID of the group.
xmin, ymin, zmin
The minimum x, y, z value for the box.
xmax, ymax, zmax
The maximum x, y, z value for the box.
A valid group must be defined previously.
None.
