*geometricrepresentations()
Creates a geometricrepresentation in HMASCII format.
*geometricrepresentations (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the geometricrepresentation.
name
The name of the geometricrepresentation.
color
The color of the geometricrepresentation. Valid values are 1-64.
To create a geometricrepresentation with ID 100, name "my-entity", and color 1:
*geometricrepresentations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021
