*alereferencesystemswitches()
Creates an alereferencesystemswitch in HMASCII format.
*alereferencesystemswitches (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the alereferencesystemswitch.
name
The name of the alereferencesystemswitch.
color
The color of the alereferencesystemswitch. Valid values are 1-64.
To create an alereferencesystemswitch with ID 100, name "my-entity", and color 1:
*alereferencesystemswitches(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
