*transformations()
Creates a transformation in HMASCII format.
*transformations (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the transformation.
name
The name of the transformation.
color
The color of the transformation. Valid values are 1-64.
To create a transformation with ID 100, name "my-entity", and color 1:
*transformations(100,"my-entity",1)
Incorrect usage results in an import error.
