*feinputwithdata2 - UG
The UG import options specified in the UG Part Browser are passed to the *feinputwithdata2 command as a string array.
The UG import options specified in the UG Part Browser are passed to the *feinputwithdata2 command as a string array. The easiest way to produce this array is to import a UG file using the desired options, and then to examine the created string array in the resulting command file. The format of the string array is as follows:
"SELECTIONS <A B C D E F G H I J>" ""
"BEGIN_PARTS" "<PART_LIST>" "END_PARTS" ""
"BEGIN_LAYERINFO" "DISABLE <DISABLED_LAYERS>" "ENABLE <ENABLED_LAYERS>" "END_LAYERINFO" ""
"BEGIN_CATEGORIES" "<CATEGORIES>" "<CATEGORIES>" "END_CATEGORIES" ""
"COMPONENT_NAME <COMPONENT_NAME_FORMAT>" ""
The <RED PARAMETERS> are user editable and have the following options, with the following values:
A
Coordinate system:
  • 0 - Global
  • 1 - Local
B
Layer filtering:
  • 0 - Midsurface only
  • 1 - Solid only
  • 2 - Solid and Midsurface
C
Create welds in HyperMesh:
  • 0 - No
  • 1 - Yes
D
Export to master weld file:
  • 0 - No
  • 1 - Yes
E
Include invisible geometry:
  • 0 - No
  • 1 - Yes
F
Display by:
  • 0 - Categories
  • 1 - Layers
G
Merge assemblies:
  • 0 - No
  • 1 - Yes
H
Part count:
  • 0 - All parts, otherwise part count
I
Save settings as default:
  • 0 - No
  • 1 - Yes
J
Include wireframe geometry:
  • 0 - No
  • 1 - Yes
<PART_LIST>
A list of all selected parts. This section is generally not user editable; its format uses UG internal entity handles. If H is 0, the <PART_LIST> should be empty (default).
<DISABLED_LAYERS>
Disabled layers, as entered in the Part Browser. If layers are enabled using <ENABLED_LAYERS>, this parameter should be blank (default). This is only required when F is 1.
<ENABLED_LAYERS>
Enabled layers, as entered in the Part Browser. If layers are disabled using <DISABLED_LAYERS>, this parameter should be blank. By default, this option is "*". This is only required when F is 1.
<CATEGORIES>
A list of categories to be imported. Each category is its own string. If this parameter is blank all categories are imported (default). This is only required when F is 0.
The component name format, as entered in the Part Browser. The default name format is "default".
