*feinputwithdata2 - Connectors
The Connector/Master Weld File import options specified in the Import workspace are written to the command file as a string array, associated with the *feinputwithdata2 command.
The Connector/Master Weld File import options specified in the Import workspace are written to the command file as a string array, associated with the *feinputwithdata2 command. The easiest way to produce this array is to import a Connector/Master Weld File file using the desired parameters, and then to examine the string array in the resulting command file.
Valid strings for the string array are as follows:
  • "HM_MAX_CE_ID <current connector max ID>"
  • "~CHARTFILE <ID map path and filename>"
