Notes and Limitations
There are several issues, limitations and special behaviors of *setvalue that are important to know.
When updating a string value, if there are any continuous spaces, the Tcl interpreter truncates these extra spaces. To prevent the truncation, specify the value to be updated as a separate string, or enter a space after the =.
// Will be interpreted as This is name, without any spaces.
*setvalue mats id=1 name={This is          name}
// Will be interpreted as This is name, with correct spaces.
*setvalue mats id=1 name= {This is          name}
or
set name "This is          name"
*setvalue mats id=1 name=$name
The HyperMesh Tcl interpreter has a 4096 character limit on the size of a string that can be passed in. Therefore, it is often necessary to use another syntax to work around this limitation. Instead of using something like this:
*createentity sets type=element name=test ids=[hm_getmark elems 1]
Examples of recommended usage are:
eval *createentity sets type=element name=test ids=[ list $elems ]
eval *createentity sets type=element name=test ids={ [hm_getmark elems 1] }
eval *createentity sets type=element name=test ids={ $elems }
Data names for beamsections, geometry entities, and morphing entities are not supported.
Some optimization entity data names are not supported.
ddvals
rangeindex
rangeindexmax
values
valuesmax
dequations
number_of_lines
string
designvars
anchorpoint
firstgrid
secondgrid
shapedesignvariable
vectorlist
vectorlistmax
desvarlinks
coeff
dobjref
objectid
dvprels
coeff
fieldposition
ishear
opticontrols
minmeth
minmethtoggle
nastran_controls
nastran_real_controls
nastran_toggles
optiresponses
coordinate_type_list
loadstepweightlist
modes
weights
The row=<row_index> option is not currently supported for the following entity types and data names.
equations
independentcoeffs
independentdofs
laminates
interfacepairplyids
plies
entitylist
entitylistdisplayed
linelist
plots
curves
curveslist
tables
marked_columnlabel
Update on row=<row_index> does not work for 1D entity attributes, and update on both row=<row_index> and column=<column_index> are not supported for all types of 2D attributes.
