*PARAMETER
.mcrash file
.mesh file
/CNODE
/CYL_JOINT
- 1 -
1D element
- 2 -
2D element
- 3 -
3D element
- A -
accelerometer
create
data history
delete
Main Module Environment File
modify
accelerometer position
import
added mass
check
create
delete
loadcase
modify
airbag folder
airbag geometry
basic notions
batch language
before starting to fold
call the safety tool
create initial geometry
cut operator
diminishing area
double-tuck fold
first tuck
fold definition
folder overview
guidelines on folding
initial geometry input
notions of geometry
open fold
quickstart guide, first fold
rectangle.nas
simple fold
subsequent tucks
superimposed tuck fold
surface distortion
theoretical manual
tuck-type fold
airbag folder theoretical manual
airbag geometry
ANSYS file format
assembly
data history
- B -
B00 File
back seat nodes
basic notions
batch language
batch language reference manual
operators
safety
type
belt
M00 Safety Module
Safety Module Environment
belt generator
bolt
.mcrash file
check
create
delete
M00 File
modify
boundary condition
create
delete
loadcase
modify
- C -
change
background color
element orientation of part
grid
mouse setting
part color
part display
part move mode
rendering options
start-up settings
Check
1D element
2D element
3D element
bolt
clip (LS-DYNA)
glue
Mig weld (LS-DYNA)
rigid body
spotweld
check list
model checker
Clean
clip, connection (LS-DYNA)
common functions, list
Common Node
concentrated load
create
delete
loadcase
modify
config
connection
connections
bolt
glue
hemming
time history setting
welding line
connectivity
Constrained (LS-DYNA)
contact
quality
contact interface
check
create
delete
loadcase
modify
convert element
create
accelerometer
bolt
clip (LS-DYNA)
glue
initial geometry
Mig weld (LS-DYNA)
nodes
relative displacement
rigid body
spotweld
time history assembly
time history element
time history node
time history part
create a group, global
create variables
in a connection
in a loadcase
in a material
in a property
Creating a Stiffener
cross-referencing
cut operator
CUT operator, operators and instructions syntax
cutting the model
Cylindrical Joint
- D -
D01
data history
database
database main table
DBL_TUCK operator
default material and property setting
define a box, global
defined displacement, undo/redo
delete
1D element
2D element
3D element
accelerometer
bolt
glue
nodes
Parts
rigid body
spotweld
time history node
time history part
variable or response
Detach Elements
dialog menu bar
different dummy views
disconnect nodes
disconnection
Display Controls
Display Options Toolbar
double-tuck fold
Drag
DRAW Instruction
DRAW_NO_LINE Instruction
DRAW_NO_PLAN Instruction
dummy
delete
restore
dummy manager
dummy parts
dummy positioner
FTSS dummy
LS-DYNA
dummy positioning
save
Duplicate Parts
- E -
Edit
Material
Property
Thickness
element
data history
Mesh Editing
quality
timestep
Ellipse/Circle Selection
encrypt, materials and properies
Entity Selection Shortcut
environment file
description
Main Module Reference Manual
Model Manager Module
EXPAND Operator
Export
File
Parts
export file, connections
extra nodes (LS-DYNA)
extract
spotwelds
- F -
failure model, create
Fast Form 3D Format
figures, list
file
Export
Import / Merge
print
Save
file format
ANSYS
Nastran
spotweld
Universal
first tuck
fixed nodes
FLPOINT_LIST Operator
fold definition
fold line
FOLD Operator
folder overview
folding guidelines
format introduction, Results Mapper Module
friction stir welding, connection (LS-DYNA)
FROM_N2N Operator
function settings
- G -
generalized weld (LS-DYNA)
geometry, notions
GET_NODE Operator
global response, create
global:
function, curve
group selection
sensor
skew frame
glue
.mcrash file
M00 File
gravity load
create
delete
loadcase
modify
group selection
GUI
guidelines for folding
- H -
hemming
.mcrash file
M00 File
HyperCrash
environment
executables
intro to options menu
reference manuals
specific input files
HyperMesh
- I -
import
File
model manager
node position
spotwelds
stamping results
import function from external file
imposed
acceleration
body velocity
displacement
temperature
velocity
imposed displacement
create
delete
modify
imposed velocity
create
delete
modify
include files
include list
information options
initial
temperature
velocity
initial geometry
create
input
initial velocity
create
INTEGER_LIST Operator
interpolation (LS-DYNA)
intersections
- J -
joints (LS-DYNA)
jpg file
- K -
Keyboard Functions
keyword
- L -
laser
load criteria file
LoadCase
imposed acceleration
imposed body velocity
imposed velocity
loadcase main table
LS-DYNA
format
tools
LS-DYNA Supported Keywords
LS-DYNA User Profile
- M -
M00 file
Main Module
Safety Module
ANSYS file format
M00 File
Nastran file format
Post-Processing input file
specific HyperCrash input files
Spotweld File Format
Universal file format
Main Window
mass
balancing
part mass details
rigid body details
material
allocate
create
model
modify
mean plane
menu
merge
dummy
nodes
Merge files
Mesh Editing
Clean
common node
Cylindrical Joint
Detach Elements
Drag
Element
HyperMesh
Move Nodes
Node
Offset Shells
Part
Remesh
Renumber
Rigid Body
Rigid Link
Smooth
Specific Renumber
SPH Generation
Spin Elements
Split Elements
MESH Operator
Mig weld, connection (LS-DYNA)
model
browser
cross-referencing
data history
hieracrchy mode
include
material
property
statistic
units manager
model checker
model direction
model manager
database
import
keyword
modify
search
store
Model Manager Module Reference Manual
B00 File
environment file
modify
1D element
2D element
3D element
a function
a point
accelerometer
bolt
clip (LS-DYNA)
glue
Mig weld (LS-DYNA)
model manager
rigid body
spotweld
time history node
time history part
modify a group, global
modify variable or response
monitored volume
create
customize
delete
loadcase
modify
Mouse Functions
move limbs
lower
upper
move nodes
define displacement
multi-movings
rotations
scaling
symmetries
translations
move the dummy
head
right location
torso
- N -
Nastran file format
NEW_LINE Operator
NEW_PLAN Operator
NEW_VECTOR Operator
nodal rigid bodies (LS-DYNA)
node
data history
Mesh Editing
node sets (LS-DYNA)
nodes
create
delete
disconnect
merge
- O -
Offset Shells
offset the mesh of parts
open fold
OPEN_FOLD Operator
Operators and Instructions Syntax
CUT Operator
DBL_TUCK Operator
DRAW Instruction
EXPAND Operator
FOLD Operator
FROM_N2N Operator
GET_NODE Operator
MESH Operator
NEW_LINE Operator
NEW_PLAN Operator
NEW_VECTOR Operator
OPEN_FOLD Operator
ORIENT Instruction
READ_FPL Operator
READ_NAS2MOD Operator
REVERSE Operator/Instruction
SELECT Instruction
SUP_TUCK Operator
TUCK Operator
UNSELECT Instruction
VECTOR_PR Operator
optimization study
option
options menu
ORIENT Instruction
- P -
PamStamp Format
parameter (LS-DYNA)
parameter (RADIOSS)
parameterization
optimization study
stochastic analysis
part
data history
mass details
penetrations
png file
pressure load
print file
process
element timestep
model manager
parameterization
submodeling
property
allocate
create
model
modify
- Q -
quality
connectivity
contact
element
load criteria file
model checker
thickness
quality criteria
quality, menu details
quickstart guide to the first fold
- R -
RADIOSS
tools
RADIOSS Supported Keywords
RADIOSS User Profile
Rayleigh damping
READ_FPL Operator
rectangle.nas
create
data history
delete
modify
Remesh
Renumber
Replace Parts
responses on elements
responses on nodes
responses on parts
responses on sections, accelerometers, rigid walls
results mapper
Results Mapper Format
Results Mapper Module Reference Manual
rigid bodies details
rigid body
check / correct
create
Mesh Editing
modify / delete
Rigid Link
rigid wall
create
delete
loadcase
modify
rivets (LS-DYNA)
RLINK
rotation, variable
- S -
safety
airbag folder
dummy positioner LS-DYNA
seat belt
seat deformer
Safety Module Reference Manual
M00 file
safety tool
scaling, variable
seat belt
seat deformer
seat parts
section
create
data history
delete
import test data
modify
section force
SELECT Instruction
settings
simple fold
simple parts
skew frame
Smooth
Specific Renumber
SPH Generation
Spin Elements
Split Elements
Splitting a Part
spotweld
.mcrash file
check
create
delete
extract
import
M00 File
modify
spotwelds (LS-DYNA)
stamping results
assign
display
import
previous session
project
save
Starting HyperCrash
Start-up Settings
statistic
model
stochastic analysis
submodeling
subsequent tucks
SUP_TUCK Operator
supported keywords
LS-DYNA
RADIOSS
surface distortion and diminishing area
- T -
tables, list
themes
thickness
quality
tie-break (LS-DYNA)
tied nodes failure (LS-DYNA)
time history
create assembly
create element
create node
create part
delete assembly
delete element
delete node
delete part
modify assembly
modify element
modify node
modify part
toolbars
Display Options
information options
transformation
define (LS-DYNA)
translate spotweld connections
translation, variable
Tree
Delete Parts
Export Parts
Introduction
Replace Parts
TUCK Operator
tuck-type fold
- U -
undo defined displacement
Unit system
units manager
changing
User Guide
User Interface Style
User Profile
- V -
variables and responses, lists of
VECTOR_PR Operator
- W -
welding line
weldline
.mcrash file
M00 File
Working Directory
