1. | From the Menu Bar, select Mesh Editing > Move. |
2. | Select the Defined Displacement radio button. |
3. | In the Selection sub-window: |
Button |
Behavior |
pick nodes in the graphic window, and then answer the question in the Dialog menu bar with Yes or Cancel. |
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add/remove object by ellipse selection. |
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
to add all nodes. |
pick parts in the graphic window, and then answer the question in the Dialog menu bar with Yes or Cancel. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add the parts selected in the tree. |
remove the parts selected in the tree. |
clear the selection. |
