HyperCrash is a CAE pre-processor developed to support RADIOSS, Altair's non-linear finite element solver. HyperCrash provides a comprehensive environment to study occupant simulations and other requirements of the crash-safety domain.
Features
| • | Extensive pre-processing capabilities for LS-DYNA and RADIOSS. |
| • | Ongoing support of RADIOSS and most keywords. |
| • | Robust tools for easy conversion of input decks from LS-DYNA to RADIOSS with minimal user intervention. |
| • | Support of PAM CRASH 2G as well as conversion from PAMCRASH to RADIOSS. |
| • | Extensive tools for crash-safety applications: model building, property and material creation, connection definition, quality checking, and more. |
| • | Full suite of welding techniques such as glue, bolts, and spot welds. |
| • | Key Safety modules: dummy positioning, seat deforming, belt generator, and airbag folding. |
| • | Extensive library of LS-DYNA and RADIOSS dummies with advanced positioning and seat-belt routing tools. |
Benefits
| • | Improves user efficiency with intuitive pre-processor interface. |
| • | Minimizes errors in LS-DYNA and RADIOSS with a reliable model check on the input deck. |
| • | Enables easy checking and removal of penetrations and intersections. |
| • | Offers numerous tailored panels to help users create and update the many cards needed to setup LS-DYNA and RADIOSS models. |
Select a topic in the table of contents, or use the List of Common Functions to find instructions on a particular function.
See Also
HyperCrash Tutorials
