1. | Merge a dummy in the model. (See Merge a dummy for more information.) |
2. | Select the desired dummy view. (See Dummy views for more information.) |
1. | Click the Ref. points toggle to display the corresponding page. |
2. | Set the following information by filling in the fields or by clicking and and picking a node, or by clicking : |
• | Side sill Z coordinate. |
• | Seat hinge X and Z coordinates. |
• | B-Pillar X coordinate. |
• | Front seat bracket X coordinate. |
• | Floor Z coordinate. |
3. | Click the H point toggle to display the corresponding page. |
4. | Set the following information by filling in the fields or by clicking and and picking a node, or by clicking : |
• | A: distance Z from the sill. |
• | B: distance Z from the seat. |
• | C: distance X from the seat. |
5. | Click the Body toggle to display the corresponding page. |
6. | Set the following information by filling in the fields or by clicking : |
• | D: distance X between the upper arm joint and the B pillar. |
• | E: distance X between the head accelerometer and the B pillar. |
• | F: distance X between the ankle joint and the front seat anchorage point. |
• | G: distance X between the ankle joints. |
• | I: distance X between the knee joints. |
7. | If necessary, manually adjust the different parts of the dummy. The different operations are defined. |
8. | In the Global dummy displacement portion of the window, set the following information by filling in the fields or by clicking , , and and picking a node, or by clicking : |
• | The Hx field: H point position in X direction. |
• | The Hy field: H point position in Y direction. |
• | The Hz field: H point position in Z direction. |
• | The Rx field: global rotation position around global X axis. |
• | The Ry field: global rotation position around global Y axis. |
• | The Rz field: global rotation position around global Z axis. |
