| 1. | From the Menu Bar, select Data History > Node > Modify. |
or
If the Data History panel is open, select Node > Modify from the pull-down menu.
| 2. | In the TH to modify list, click the group to be modified. |
| 3. | Click to display the time history node(s) in the graphic window. |
It is possible to:
| • | Modify the TH node group name by setting a new name in the TH name field. |
| • | Modify the time history node names (see Node name). |
| 4. | Click Save to save the time history node modifications; or |
Click Cancel to cancel the time history node modifications.
| 5. | Click Close to close the menu. |
