| 1. | From the Menu Bar, select Data History > Node > Modify. |
or
If the Data History panel is open, select Node > Modify from the pull-down menu.
It is possible to directly delete a time history node group or, in a group, to delete a time history node.
Delete a time history node group
| 1. | Click the time history node group to be deleted. |
| 2. | Click . |
| 3. | Answer the question in the Dialog menu bar with Yes or Cancel. |
Delete a time history node in a group
| 1. | Click the time history node group from which a time history node is to be deleted. |
| 2. | Click to display the time history node(s) in the graphic window. |
| 3. | From the time history node list, select the time history node to delete. |
| 4. | Click . |
| 5. | Answer the question in the Dialog menu bar with Yes or Cancel. |
