| 1. | From the Menu Bar, select Data History > Node > Create. |
or
If the Data History panel is open, select Node > Create from the pull-down menu.
| 2. | Enter a name in the Node for time history field and validate with Ok. |
| 3. | Click and pick nodes in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
or
Set a node ID in the Node Id field and click Ok.
| 4. | In the node list, click the desired node to highlight it. |
A name can be imposed for each time history node. In Block Format this name will be saved and TH++ will use this specific name.
| 5. | Click to display the node in green in the graphic window. |
| 6. | In the Node name field, enter the new name and click Ok. |
| 7. | Using the radio buttons, select from: Global, Moving Local or Fixed Local. |
| 8. | Click Save to save the time history nodes; or |
Click Cancel to cancel the time history node creation.
| 9. | Click Close to close the menu. |
