Use the Imposed Body Velocity option from the LoadCase menu to create, delete, edit, or cross-reference an imposed body velocity card (/IBVEL).
In the Imposed Body Velocity panel, right-click to access the context menu, and make a selection from the choices of Review, Create New, Delete, Rename, and Cross Reference.
| Note: | Selected imposed body velocities may be turned ON or OFF in the display through the Model Browser. |
All imposed body velocities can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
| 1. | When you select Create New from the context menu, the IBVEL card panel appears. |
| 2. | Click to expand the Support sub-menu and make selections from these menus as applicable. |
| 3. | Click Save or Cancel when you are finished creating the card. |
