Use the Imposed Acceleration option from the LoadCase menu to create, delete, edit, or cross-reference an imposed acceleration card (/IMPACC).
In the Imposed Acceleration panel, right-click to access the context menu, and make a selection from the choices of Review, Create New, Delete, Rename, and Cross Reference.
| Note: | Selected imposed accelerations may be turned ON or OFF in the display through the Model Browser. |
All imposed accelerations can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
Creating a new imposed acceleration:
| 1. | When you select Create New from the context menu, the IMPACC card panel appears. |
| 2. | Click to edit fields and right-click in applicable fields for more options. |
| 3. | Click to expand the Skew, Sensor, and Support sub-menus and make selections from these menus as applicable. |
| 4. | Click Save or Cancel when you are finished creating the card. |
