| 1. | From the Menu Bar, select Contact Interface > Create / Modify. |
Button |
Behavior |
select all the contact interfaces. |
pick the arrow for the contact interface in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select contact interfaces by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the contact interfaces applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select parts by box (use the SHIFT key to use a polygon box) to select all contact interfaces applied to those parts. |
to get external surfaces of solid part(s). |
Click the contact interface line in the listing window to select it. Several contact interfaces of this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
| 2. | Select only one contact interface and click |
| • | Change the group's definition (See Group selection). |
| • | Modify the interface properties (see Properties). |
| o | Use the pop-up function (right button on the mouse in the interface list window). |
| o | Check penetrations for the selected interfaces (intersection and penetration). |
| o | Set the selected interface in the time history file. |
| 3. | Click |
| 4. | Answer the question in the pop-up dialog window with Yes or Cancel. |
| 5. | Click Save to save the modified interface. |
or
Click Save + Sym. to save the interface and automatically create its symmetric: the slave side becomes the master, and the master side becomes the slave (not available for a Self-Impact interface).
or
Click Cancel to cancel the contact interface modification.
| 6. | Click Close to close the menu. |
