| 1. | From the Menu Bar, select LoadCase > Contact Interface. |
| 2. | Right-click to access the context menu and make a selection from the list. |
| 3. | Click the Choose Contact drop-down list and select an interface type. |
| 4. | Click the Selection sub-window. |
| 5. | Select one of the following: |
| • | Slave to define the slave group of the interface. |
| • | Master to define the master group of the interface. |
| • | See to display the selected surfaces: the master surfaces in blue, and the slave ones in red. |
| 7. | Click the Properties tab. |
| 9. | Define the different required parameters. |
| 10. | Click Save to save the created interface. |
or
Click Save + Sym. to save the interface and automatically create its symmetric: the slave side becomes the master, and the master side becomes the slave (not available for a Self-Impact interface).
or
Click Cancel to cancel the interface creation.
| 11. | Click Close to close the menu. |
Go to
Contact Interface
