/WELDLINE/Nbpoint/id(/title)
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the number of part or subpart to weld (Integer < 6) |
Integer |
No |
is the identifier number of the spotweld |
Integer |
No |
is the name of the spotweld |
String |
No |
This is the same format as the spotweld. Only the keyword is changed.
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /WELDLINE/2/3 -678.822 -449.455 301.25 -678.822 -449.455 301.25 1 2 UNCREATED #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /WELDLINE/3/7 -670.155 -519.814 299.2 -670.155 -519.814 299.533 -670.155 -519.814 300.013 1 2 CREATED /NODE/12844 /NODE/12843 /NODE/12845 /SPRING/7 /SPRING/9 /INTER/53 /INTER/54 /INTER/55 /SHELL/358 /SH3N/1456 /SHELL/567 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
