This document presents the details of the directories that exist in HyperCrash and describes the specific HyperCrash files within the directories.
The HyperCrash software contains directories for the following:
Executable Directory
The directory of the executable files is called $MCRASHEXE. This is a variable you need to set in your shell environment (csh format):
MCRASHEXE = <ALTAIR_HOME>/hc/bin/<os_type>/
Environment Directories
This directory contains the reference parameter files of HyperCrash. This directory is unit system dependant.
The environment directory contains different sub-directories according to the output format of the model:
| LSDYNA | to output LS-DYNA model |
| PAM2G | to output LS-DYNA model |
| RADIOSS_V4 | to output RADIOSS V4.1, V4.2 and V4.4 model |
| RADIOSS_V5 | to output RADIOSS V5.1 model |
Each sub-directory contains a list of environment directories according to the unit system:
| • | environment (LSDYNA, PAM2G, RADIOSS_V4, RADIOSS_V5, RADIOSS_V9, RADIOSS_V10, RADIOSS_V11, RADIOSS_V12, RADIOSS_V13) |
The directory of the environment files is named $MCRASHDIR.
Configuration Directories
This directory contains the reference parameter files for HyperCrash.
| RADIOSS_V4 | to output RADIOSS V4.1, V4.2, V4.3 and V4.4 model |
The following variables must be defined in order to take into account the selected configuration:
Example for RADIOSS_V4 output format:
MV_VER_DIR = 4.4:4.3:4.4:4.1
MV_CFG_DIR = <ALTAIR_HOME>/hc/config/RADIOSS_V4
Main Module Environment File Description
Specific HyperCrash Input Files
Spotweld File Format Description
Post-Processing Input File
Nastran File Format
ANSYS File Format
Universal File Format
M00 File Description
