This document describes all the spotweld file formats that HyperCrash is able to read. If you need another specific format, please contact: hwsupport@altair.com
This is a text file with the following cards. HyperCrash is able to import and export this spotweld file format.
/SPOTWELD/Nb_part/id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the number of part or subpart to weld (Integer < 6) |
Integer |
No |
is the identifier number of the spotweld |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
x_I |
y_I |
z_I |
Where: |
Type |
Unit |
Global Coordinates of points defining the position of the spotweld for each part or subpart to weld: one Card for each point. Nbpoint card has to be defined. |
Real |
Length |
Real |
Length |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
part_1 |
part_Nbpoint |
Where: |
Type |
Unit |
is the identifiers number of the parts to weld |
Integer |
No |
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/SPOTWELD/2/3
-678.822 -449.455 301.25
1 2
/END
Id_spotweld::nb_plate::x_coord::y_coord::z_coord::Id_prop_1::Id_prop_2::…
Where: |
Type |
Unit |
Integer |
No |
is the number of parts to weld |
Integer |
No |
is the x coordinate of the spotweld |
Real |
Length |
is the y coordinate of the spotweld |
Real |
Length |
is the z coordinate of the spotweld |
Real |
Length |
is the property identifier of the part to weld (2 < i < 5) |
Integer |
No |
is the field separator |
Character |
No |
HyperCrash will try to weld the parts linked to the defined property (up to five properties).
1016::3::2094.178500::-778.072000::781.493150::500::500::125
Id_spotweld,x_coord,y_coord,z_coord,Id_prop_1,Id_prop_2,…
Where: |
Type |
Unit |
is the identifiers number of the spotweld |
Integer |
No |
Real |
Length |
Real |
Length |
Real |
Length |
is the property identifier of the part to weld (2 < i < 5) (optional) |
Integer |
No |
Character |
No |
62016,2094.178500,-778.072000,781.493150,1234,6423,4654
62016,1024.13543,-458.0,12.34653
SPOT,Id_spotweld,nb_plate,x_coord,y_coord,z_coord,Id_prop_1,Id_prop_2,…
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
Integer |
No |
Integer |
No |
Real |
Length |
Real |
Length |
Real |
Length |
Integer |
No |
Character |
No |
SPOT,62016,2,2094.178500,-778.072000,781.493150,1265,7532,
SPOT,62016,3,2045.176700,-798.120400,657.486350,1264,7632,18654,
