This document describes all the post-processing file formats that HyperCrash is able to read. If you need another specific format, please contact: hwsupport@altair.com
This is a text file (.csv) defined with the following cards.
For each node, three lines have to be defined with:
| • | Node_label_X, coordinate value in X direction |
| • | Node_label_Y, coordinate value in Y direction |
| • | Node_label_Z, coordinate value in Z direction |
Use the following characters to separate the different fields: ”,”, ”or” or ”blank”.
| Note: | The node label must not contain these 3 characters. |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
Dashboard_lower_position_1_X,1234.098
Dashboard_lower_position_1_Y,0
Dashboard_lower_position_1_Z,-125.754
Dashboard_lower_position_2_X,1234.098
Dashboard_lower_position_2_Y,-150
Dashboard_lower_position_2_Z,-125.754
This is a text file (.txt) defined with the following cards.
For each node, one line is defined with:
| • | X_coordinate Y_coordinate Z_coordinate Node_label |
To separate the different fields, use the space character.
1234.098 0 -125.754 Dashboard_lower_position_1
1234.098 –150 -125.754 Dashboard_lower_position_1
