Only the read function is now existing. ANSYS (.cdb) version 5.6 and 5.7 are supported.
The following elements can be read:
| • | SHELL 43, 63, 93 & 181 |
| • | SOLID 95, 45, 72 & 92 |
| • | BEAM 4, 24 & 44 |
| • | PIPE 16 |
| • | MASS 21 |
ANSYS |
RADIOSS |
Notes |
NBLOCK |
double precision nodes |
NODE |
EBLOCK |
SHELL 43 |
SHELL & SH3N |
SHELL 63 |
SHELL & SH3N |
SHELL 93 |
SHELL & SH3N |
SHELL 181 |
SHELL & SH3N |
SOLID 95 |
BRICK |
20 nodes to 8 nodes* |
SOLID 45 |
BRICK |
SOLID 72 |
TETRA4 |
SOLID 92 |
TETRA10 |
BEAM 4 |
BEAM |
3rd node created |
BEAM 44 |
BEAM |
3rd node created |
BEAM 24 |
BEAM |
PIPE 16 |
TRUSS |
MASS 21 |
ADMAS |
RLBLOCK |
PROP/SHELL |
Thickness read |
PROP/SOLID |
Default values assigned |
BEAM 4 & 44 |
PROP/BEAM |
Area, Ixx, Iyy & Izz read |
BEAM 24 |
PROP/BEAM |
PIPE 16 |
PROP/TRUSS |
Ø & wall thickness read |
MASS 21 |
Mass read |
MPTEMP |
EX, EY, EZ, NUXY, NUYZ, NUXZ & DENS |
MAT/LAW1 & MAT/LAW14 |
If material is missing or is not supported, default material = LAW2 |
*20 nodes Solid is transformed into 8 nodes Solid. 20 nodes Hexahedron not yet supported by RADIOSS.
