This section shows all the HyperCrash environment parameter files. All the files are located in the directory named $MCRASHDIR.
The environment file enables you to modify or customize the values over the default values that will be used when performing certain operations in HyperCrash.
They are unit dependent in some cases.
HyperCrash supports bolts and bolts are represented in a cylinder attached to the base. The diameter and height of the cylinder can be modified, as well as the name and properties.
