This section shows all the HyperCrash environment parameter files. All the files are located in the directory named $MCRASHDIR.
After a keyword, the lines are formatted with 80 characters divided into 10 fields of eight characters (like in RADIOSS Starter Input Deck).
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
The unused fields are displayed in gray.
The first character of a comment line is #.
The unit and the type of each parameter are defined as the following:
| Unit: | Length: mm, cm, dm, m … |
| Time: | s, ms… |
| Mass: | g, kg, t… |
| Force: | N, kN… |
The selected unit system must be consistent with an equivalent S.I. unit system.
Example of unit systems:
Length |
Time |
Mass |
Force |
Pressure |
Velocity |
Density |
Energy |
g |
m |
s |
kg |
N |
Pa |
m/s |
kg/m3 |
J |
9.81 |
mm |
s |
t |
N |
MPa |
mm/s |
t/mm3 |
mJ |
9.81e+3 |
mm |
ms |
kg |
kN |
GPa |
m/s |
kg/mm3 |
J |
9.81e-3 |
mm |
ms |
g |
N |
MPa |
m/s |
g/mm3 |
mJ |
9.81e-3 |
