/HEMMING/Nbpoint/id(/title)
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the number of part or subpart of the hemming (Integer < 6) |
Integer |
No |
is the identifier number of the hemming |
Integer |
No |
is the name of the hemming - optional |
String |
No |
This is the same format as the spotweld. Only the keyword is changed.
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /HEMMING/2/3 -678.822 -449.455 301.25 -678.822 -449.455 301.25 1 2 UNCREATED #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /HEMMING/3/7 -670.155 -519.814 299.2 -670.155 -519.814 299.533 -670.155 -519.814 300.013 1 2 CREATED /NODE/12844 /NODE/12843 /NODE/12845 /SPRING/7 /SPRING/9 /INTER/53 /INTER/54 /INTER/55 /SHELL/358 /SH3N/1456 /SHELL/567 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
/CONNEC/TYPE/id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword which is the type of connection:
Integer |
No |
is the identifier number of the connection |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Nb_elem |
Where: |
Type |
Unit |
is the number of elementary connection of the type defined in the keyword line |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Elem_1 |
Elem_2 |
Elem_10 |
elem_Nb_elem |
Where: |
Type |
Unit |
is the identifier number of elementary connection. |
Integer |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /CONNEC/SPOTWELD/19 1 19 /CONNEC/BOLT/20 1 20 /CONNEC/WELDLINE/21 7 1 2 3 4 5 6 7 /CONNEC/HEMMING/22 9 1 2 3 4 5 6 7 8 9 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
