/GLUE/glue_type/param/glue_id(/title)
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is keyword which defines the glue type:
Keyword |
No |
is the spring property ID of the glue in the D00 file if the glue type is AUTO. |
Integer |
No |
is the identifier number of the glue |
Integer |
No |
is the name of the glue - optional |
String |
No |
The glue with the type AUTO and AREA can be only UNCREATED.
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Part_1 |
Part_2 |
Gap |
Property_Name |
Where: |
Type |
Unit |
is the identifier number of the first part to weld |
Integer |
No |
is the identifier number of the second part to weld |
Integer |
No |
is the distance value to search the part |
Real |
No |
is the file name of the springs property of the glue. The spring property file should be stored in the directory $HCRASHDIR/property (text). |
Integer |
No |
Where Property_Name is a string giving the name of the property or the name of the file in which the property will be read.
This card has to be defined only for type = LINE or AREA
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
x_part_1 |
y_part_1 |
z_part_1 |
x_part_2 |
y_part_2 |
z_part_2 |
Where: |
Type |
Unit |
Global coordinates of points defining the position of the glue for the both part or subpart to weld: one Card for each point and each point. |
Real |
Length |
Real |
Length |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Status |
Where: |
Type |
Unit |
is a keyword which defines the status of the glue:
The string has to be left-justified. |
Keyword |
No |
| 1. | If status is UNCREATED, it means that the glue modeling is not in the input deck, but HyperCrash keeps only its geometrical description in the M00 file (from Card 1 and 2). |
| 2. | If status is CREATED, the following keyword lines will be added for each glue connection: |
/NODE/Nod_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier number of nodes defined in the associated D00 file (nodes of the spring element). |
Integer |
No |
This keyword line will be written twice, for both nodes of the spring.
/SPRING/spring_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of one of the springs of the glue |
Integer |
No |
/INTER/inter_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of one of the interfaces of the glue |
Integer |
No |
/Element/element_id
Where: |
Type |
Unit |
is a keyword which can be:
Keyword |
No |
is the identifier of one of the SHELL or SH3N element of the glue |
Integer |
No |
This keyword line will be written twice, one for each nodes of the spring element.
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /GLUE/LINE/3/16 3 4 0.000000SPRI_13_Glue 25.271300 46.455500 0.000000 25.271300 46.455500 5.000000 35.271300 46.455500 0.000000 35.271300 46.455500 5.000000 45.271300 46.455500 0.000000 45.271300 46.455500 5.000000 UNCREATED /GLUE/AREA/4/17 3 4 0.000000SPRI_13_Glue 31.000000 62.000000 0.300000 31.000000 62.000000 7.000000 31.000000 47.000000 0.500000 31.000000 48.000000 8.000000 50.000000 34.000000 0.000000 50.000000 33.000000 7.000000 68.000000 56.000000 0.400000 68.000000 58.000000 7.000000 UNCREATED /GLUE/AUTO/0/18/automatic glue 3 4 20.00000SPRI_13_Glue UNCREATED #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /GLUE/LINE/3/16 3 4 0SPRI_13_Glue 35.2713 46.4555 0.75 35.2713 46.4555 6.2 25.2713 46.4555 0.75 25.2713 46.4555 6.2 45.2713 46.4555 0.75 45.4872698 45.9418162 6.54751341 CREATED CREATED /NODE/586 /NODE/587 /SPRING/1 /INTER/1 /INTER/2 /SHELL/202 /SHELL/317 CREATED /NODE/588 /NODE/589 /SPRING/2 /INTER/1 /INTER/2 /SH3N/622 /SH3N/667 UNCREATED #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
