/BOLT/Nb_part1/Nb_part2/Type_bolt/Bolt_id(/Title)
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the number of part in the set 1 |
Integer |
No |
is the number of part in the set 2 |
Integer |
No |
is a flag which defines the type of bolt:
Integer |
No |
is the identifier number of the bolt |
Integer |
No |
is the name of the bolt - optional |
String |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
X_center |
Y_center |
Z_center |
Where: |
Type |
Unit |
is the global coordinate value of the geometrical center of the bolt. |
Real |
Length |
Real |
Length |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
X_vect |
Y_vect |
Z_vect |
Where: |
Type |
Unit |
defines component of the bolt axle in the global coordinate system. |
Real |
No |
Real |
No |
Real |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Length1 |
Length2 |
Diameter |
Where: |
Type |
Unit |
is the search distance in negative direction on the axle of the bolt. |
Real |
Length |
is the search distance in positive direction on the axle of the bolt. |
Real |
Length |
is the search diameter of the bolt. |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Part1,1 |
Part1,2 |
Part1,10 |
Part1,nb1 |
Where: |
Type |
Unit |
are the identifier numbers of the parts of the set 1 (10 parts per line). |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Part2,1 |
Part2,2 |
Part2,10 |
Part2,nb2 |
Where: |
Type |
Unit |
are the identifier numbers of the parts of the set 2 (10 parts per line). |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Status |
Where: |
Type |
Unit |
is a keyword which define the status of the bolt:
The string has to be left-justified. |
Keyword |
No |
| 1. | If status is UNCREATED, it means that the bolt modeling is not in the input deck, but HyperCrash keeps only its geometrical description in the M00 file (from Card 1 to 6). |
| 2. | If status is CREATED, the following keyword lines will be added: |
/NODE/Nod_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of the nodes. In case of deformable bolt, four nodes will be defined:
In case of rigid bolt, two nodes will be defined:
Integer |
No |
/SPRING/spring_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of the spring. This card is required only in the case of deformable bolt. |
Integer |
No |
/RBODY/rbody_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of the rigid bodies:
Integer |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /BOLT/1/0/0/3/susp_arg 1117.09 557.936 790 0.042071 -0.254517 0.966153 5 5 80 110016 2478 UNCREATED #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /BOLT/1/2/2/1/New_Bolt -642.4 486.071 260.389 -1 0 0 100 100 40 1 3 5 CREATED /NODE/12883 /NODE/12884 /NODE/12885 /NODE/12886 /SPRING/21 /RBODY/2 /RBODY/3 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /BOLT/1/3/1/2/1 4957.2555 -584.953 1155.805 0 0 1 100 100 90 459 384 388 389 CREATED /NODE/328707 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
