/SPOTWELD/Nbpoint/id(/title)
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the number of part or subpart to weld (Integer < 6) |
Integer |
No |
is the identifier number of the spotweld |
Integer |
No |
is the name of the spotweld |
String |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
x_I |
y_I |
z_I |
Where: |
Type |
Unit |
Global Coordinates of points defining the position of the spotweld for each part or subpart to weld: one Card for each point. Nbpoint card has to be defined. |
Real |
Length |
Real |
Length |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
part_1 |
part_Nbpoint |
Where: |
Type |
Unit |
is the identifier number of the parts to weld |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Status |
Where: |
Type |
Unit |
Is a keyword which defines the status of the spotweld:
The string has to be left justified. |
Keyword |
No |
| 1. | If status is UNCREATED, it means that the spotweld modeling is not in the input deck, but HyperCrash keeps only its geometrical description in the M00 file (Nbpoint, coordinates of points, list of parts to weld). |
| 2. | If status is CREATED, the following keyword lines will be written for each spotweld connection: |
/NODE/Nod_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of one of the nodes of the spring of the spotweld |
Integer |
No |
This keyword line will be written Nbpoint times.
and Np-1 lines with:
/SPRING/spring_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of one of the springs of the spotweld |
Integer |
No |
This keyword line will be written Nbpoint-1 times.
/INTER/inter_id
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier of one of the interface of the spotweld |
Integer |
No |
/Element/element_id
Where: |
Type |
Unit |
is a keyword which can be:
Keyword |
No |
is the identifier for one of the SHELL or SH3N element of the spotweld |
Integer |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /SPOTWELD/2/3 -678.822 -449.455 301.25 -678.822 -449.455 301.25 1 2 UNCREATED #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /SPOTWELD/3/7 -670.155 -519.814 299.2 -670.155 -519.814 299.533 -670.155 -519.814 300.013 1 2 3 CREATED /NODE/12844 /NODE/12843 /NODE/12845 /SPRING/7 /SPRING/9 /INTER/53 /INTER/54 /INTER/55 /SHELL/358 /SH3N/1456 /SHELL/567 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
