| 1. | From the Menu Bar, select Data History > Element > Create. |
or
If the Data History panel is open, select Element > Create from the pull-down menu.
| 2. | Select the type of element: |
Button |
Behavior |
creates TH 3-nodes shell elements |
creates TH 4-nodes shell elements |
creates TH solid elements |
creates TH trusses |
creates TH beams |
creates TH springs |
| 3. | Enter a name in the Element for time history field and validate with Ok. |
| 4. | Click |
or
Set an element ID in the Element Id field and click Ok.
| 5. | A name can be imposed for each time history element. In Block Format, this name will be saved and TH++ will use this specific name. |
| 6. | In the Element List, click the desired element. |
| 7. | In the Element name field, enter the new name and click Ok. |
| 8. | Click Save to save the time history elements; or |
Click Cancel to cancel the time history elements creation.
| 9. | Click Close to close the menu. |
