| 1. | From the Menu Bar, select LoadCase > Concentrated Load > Modify. |
| 2. | Select concentrated loads using one of the following methods: |
Button |
Behavior |
select all the concentrated loads |
pick the arrow of the concentrated load in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel |
select concentrated load by box (use the SHIFT key to use a polygon box) |
pick parts in the graphic window to select all the concentrated load applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select parts by box (use the SHIFT key to use a polygon box) to select all concentrated load applied to those parts |
| 3. | Select only one concentrated load and click |
| • | Change the concentrated load name. |
| • | Select or deselect nodes or parts (see Node selection). |
| • | Modify the skew frame (see reference axis). |
| • | Modify the sensor (see Sensor). |
| • | Modify the properties (see Properties setting). |
| • | Modify the concentrated load direction (see Direction setting). |
| 4. | Click |
| 5. | Click Save to save the modified concentrated load; or |
Click Cancel to cancel the concentrated load modification.
| 6. | Click Close to close the menu. |
