This option appears in any module in which a sensor can be set and defined.
Create or Modify a Sensor
In the sensor folder:
| 1. | Click the sensor list menu and select a sensor type. |
| • | If the selected sensor is TIME: |
| o | Enter the time value when the sensor will be activated. |
| • | If the selected sensor is DIST: |
| o | Click and select the two nodes which will define the distance. |
| o | Enter the time delay for the sensor activation. |
| o | Enter the minimum distance between the two selected nodes to activate the sensor. |
| o | Enter the maximum distance between the two selected nodes to activate the sensor. |
The sensor will be activated when the minimum or maximum distance is reached and after the time delay.
| 2. | To save the created sensor, click Save; or to delete the created sensor, click Delete. |
