| 1. | From the Menu Bar, select Data History > Section > Create. |
or
If the Data History panel is open, select Section > Create from the pull-down menu.
| 2. | Enter a name in the Section field and validate with Ok. |
| 3. | Select parts in one of the following methods: |
| • | Click and pick parts in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
| • | Click to add the parts selected in the tree. |
| • | Click to add parts by box selection: |
| o | The default box is rectangular. |
| o | Use the SHIFT key to define a polygon box. |
| • | Click to remove parts by box selection: |
Section plane normal
| 1. | Select the section normal direction by clicking in X, in Y, or in Z. |
| 2. | In the Position field, enter a value and click to display the section in the graphic window. |
The blue nodes define the section local skew frame. They are automatically computed to have a local skew frame as close as possible to the section center.
| 3. | If necessary, redefine the local skew frame by clicking and, in the graphic window, picking three nodes. |
By picking:
| 1. | Click the 3 nodes radio button to activate. |
| 2. | In the graphic window, click the three nodes that will define the section plane. |
Section components
Select components using one of the following methods:
| • | Click to reverse the section side. The local skew frame is automatically updated. |
| • | In the Element add/remove, click and, in the graphic window, pick shell elements to add or remove them from the section definition. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
| • | To Add element, click and in the graphic window, drag a box to select shell elements. |
| • | To Remove element, click and in the graphic window, drag a box to deselect shell elements. |
| • | In the Node add/remove, click and in the graphic window, pick nodes to add or remove them from the section definition. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
| • | To Add node, click and in the graphic window, drag a box to select nodes. |
| • | To Remove node, click and in the graphic window, drag a box to deselect nodes. |
Validation
| 1. | Click Save to save the section; or |
Click Cancel to cancel the section creation.
| 2. | Click Close to close the menu. |
