| 1. | From the Menu Bar, select Data History > Section > Modify. |
or
If the Data History panel is open, select Section > Modify from the pull-down menu.
| 2. | In the Section to modify list, click the section to be modified. |
| 3. | Click |
It is possible to:
| • | Modify the section name by setting a new name in the Section name field. |
| • | Modify the section position (see Section plane normal). |
| • | Modify the section components (see Section components). |
| 4. | Click Save to save the section modifications; or |
Click Cancel to cancel the section modifications.
| 5. | Click Close to close the menu. |
