| 1. | From the Menu Bar, select Data History > Section > Modify. |
or
If the Data History panel is open, select Section > Modify from the pull-down menu.
| 2. | In the Section to modify list, click the section to be deleted. |
| 3. | Click |
| 4. | Answer the question in the Dialog menu bar with Yes or Cancel. |
