Use the Common Node (
) option from the Mesh Editing menu to create, delete, edit, or cross reference a Common Node card (/CNODE).
In the Common Node panel, right-click to access the context menu, and make a selection from the available choices.
| Note: | Selected Common nodes may be turned ON or OFF in the display through the Model Browser. |
All Common nodes can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
Create a new Common Node.
| 1. | When you select Create New from the context menu, the CNODE card panel appears. |
| 2. | Click to edit fields and right-click in applicable fields for more options. |
| 3. | Click to expand the Support sub-menu and make selections from this menu as applicable. |
| 4. | Click Save or Cancel when you are finished creating the card |
