Use the Cylindrical Joint (
) option from the Mesh Editing menu to create, delete, edit, or cross reference a Cylindrical Joint card (/CYL_JOINT).
In the Cylindrical Joint panel, right-click to access the context menu, and make a selection from the available choices.
| Note: | Selected cylindrical joints may be turned ON or OFF in the display through the Model Browser. |
All cylindrical joints can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
Create a new cylindrical joint.
| 1. | When you select Create New from the context menu, the /CYL_JOINT card panel appears. |
| 2. | Click to edit fields and right-click in applicable fields for more options. |
| 3. | Click to expand the Support sub-menu and make selections from this menu as applicable. |
| 4. | Click Save or Cancel when you are finished creating the card. |
