/BELT_GEN/partid
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is the identifier number of the part of the belt in the associated RADIOSS input deck file (D00) |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Nnode |
Npart |
Where: |
Type |
Unit |
is the number of nodes used to define the belt |
Integer |
No |
is the number of part of the dummy model used to define the dummy external surface |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Node_1 |
Node_2 |
Node_10 |
Node_Nnode |
Where: |
Type |
Unit |
is the identifier number of nodes used to define the belt |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Part_1 |
Part_2 |
Part_10 |
Part_Npart |
Where: |
Type |
Unit |
is the identifier number of part used to define the dummy external surface |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
x_1 |
y_1 |
z_1 |
x_Nnode |
y_Nnode |
z_Nnode |
Where: |
Type |
Unit |
is the coordinate values (in the global frame) of the Nnode nodes listed previously. |
Integer |
No |
Integer |
No |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Elem_type |
Rbcreat |
Fixp |
Where: |
Type |
Unit |
is a flag which define the type of element used for the seat belt:
Flag |
No |
is a flag to create automatically the rigid body on the tops of the seat belt:
Flag |
No |
is a flag to allow the displacement of the reference points according the gap value:
Flag |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Gap |
Width |
Where: |
Type |
Unit |
is contact interface gap between the dummy and the seat belt |
Real |
Length |
is the width of the seat belt |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Nleng |
Nwidth |
Where: |
Type |
Unit |
is the number of element in the length of the seat belt |
Integer |
No |
is the number of element in the width of the seat belt |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Part |
Mat |
Prop |
Where: |
Type |
Unit |
is the identifier number of the seat belt part (same ID as the one defined in the keyword line) |
Integer |
No |
is the identifier number of the seat belt material |
Integer |
No |
is the identifier number of the seat belt property |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Master1 |
Master2 |
Where: |
Type |
Unit |
is the identifier number of the master node of the first rigid body (defined only if the flag, Rbcreat = 1) |
Integer |
No |
is the identifier number of the master node of the second rigid body (defined only if the flag, Rbcreat = 1) |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
V1x |
V1y |
V1z |
V2x |
V2y |
V2z |
Where: |
Type |
Unit |
is the component of the direction vector of the first top of the seat belt |
Real |
No |
is the component of the direction vector of the second top of the seat belt |
Real |
No |
