The M00 file is a file which contains the information which does not exist in the D00 (RADIOSS Block Format only).
The keywords described here are:
| • | DUMMY_POS |
| • | BELT_GEN |
/DUMMY_POS/Id/Title
Where: |
Type |
Unit |
Is a keyword |
Keyword |
No |
Is the identifier number of the dummy |
Integer |
No |
Is the name of the dummy, name displayed in the Safety page. |
String |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Subset |
Grnod |
Where: |
Type |
Unit |
is the identifier number of a subset defined in the associated D00 file, and corresponding to the Dummy. |
Integer |
No |
is the identifier number of a node group defined in the associated D00 file. |
Integer |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Hx |
Hy |
Hz |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Rx |
Ry |
Rz |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Side sill (point 1) |
Hinge_x (point 2) |
Hinge_z (point 2) |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
B-pillar (point 3) |
Bracket (point 4) |
Floor (point 5) |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
A |
B |
C |
D |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
E |
F |
G |
I |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Left_alpha_x |
Left_alpha_y |
Left_alpha_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Left_beta_x |
Left_beta_y |
Left_beta_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Left_theta_x |
Left_theta_y |
Left_theta_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Right_alpha_x |
Right_alpha_y |
Right_alpha_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Right_beta_x |
Right_beta_y |
Right_beta_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Right_theta_x |
Right_theta_y |
Right_theta_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Left_phi_x |
Left_phi_y |
Left_phi_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Left_omega_x |
Left_omega_y |
Left_omega_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Left_gamma_x |
Left_gamma_y |
Left_gamma_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Right_phi_x |
Right_phi_y |
Right_phi_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Right_omega_x |
Right_omega_y |
Right_omega_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Right_gamma_x |
Right_gamma_y |
Right_gamma_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Kappa_x |
Kappa_y |
Kappa_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Lambda_x |
Lambda_y |
Lambda_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Eta_x |
Eta_y |
Eta_z |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Angle_11 |
Angle_12 |
Angle_13 |
Angle_21 |
Angle_22 |
Angle_23 |
Angle_31 |
Angle_32 |
Angle_33 |
