The file, $MCRASHDIR/dummng/database_main.tbl defines the path of the different databases:
Two types of database may be defined:
| • | Private database: just for the user |
| • | Public database: for any user |
This card defines the type of database and their path:
/DUMMNG/DATABASE/type
<full_path>database_name_table.tbl
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword which define the type of database :
Keyword |
No |
is the file name (with the full path) of the database table list of each databases |
String |
No |
Several database tables can be defined under this keyword line.
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
/DUMMNG/DATABASE/PRIVATE $HOME/private_database/private_dummy_database_1.tbl /DUMMNG/DATABASE/PUBLIC $MCRASHDIR/database/dummy_database1.tbl $MCRASHDIR/database/dummy_database2.tbl /END |
For each database, there is only one table file (.tbl). This file defines all the sub-models (B00 files) located in the database.
This card defines the database path:
/DUMMNG/DATABASE/DIRECTORY
directory_path
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the default directory path where the dummy model will be stored |
String |
No |
/DUMMNG/IMPORT/ONLY_DATABASE/YES
Option to deactivate the page (D00) where the user can read a dummy model which is not set in the database.
/DUMMNG/DATABASE/MODEL
/path/File_name
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Key_1 |
Key_2 |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the file name of the dummy model defined with its full path and/or with the variable, $MCRASHDIR. |
String |
No |
is the keyword list used to defined the model. The keywords are defined in the file, $MCRASHDIR/dummng/keyword.tbl |
String |
No |
To write a keyword with more than eight characters, the character ’@’ will be set at the first position of the next field (See the section, Keyword).
/END
Where: |
Type |
Unit |
Keyword |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/DATABASE/DIRECTORY $DUMMY_BASE #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/DATABASE/MODEL $DUMMY_BASE/H350R12BD00 HYBRID_I@II 50 RIGID #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /END |
The dummy database will be defined with the variable, DUMMY_BASE.
