This section defines the necessary files used by the Safety menu.
The model will be located in the database with a keyword list that will be used to research the model in the database. All the keywords are defined in the file, $MCRASHDIR/dummng/keyword.tbl.
Each keyword list is defined inside a keyword group:
/DUMMNG/KEYWORD
keyword_group_name
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Key_1 |
Key_2 |
Where: |
Type |
Unit |
is a keyword |
Keyword |
No |
is a keyword |
Keyword |
No |
is the name of the keyword group |
String |
No |
is the keyword list of the group of keyword (eight characters) |
String |
No |
To write a keyword with more than eight characters, the character ’@’ will be set at the first position of the next field (See the keyword, HYBRID_III in the Example below).
/END
Where: |
Type |
Unit |
Keyword to finish the input. |
Keyword |
No |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/KEYWORD Norm EUROSID USSID HYBRID_I@II #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/KEYWORD Person ADULT CHILD #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /END |
